interalian
Thread starter- Joined
- Jul 23, 2009
- 2,105
Pretty sure I'm passing 4400 rpm, but the tach seems to disagree. Thoughts??
https://youtu.be/36-azXGY-0g
That makes sense if the needle is mechanically sticking at 4400, oil it :lol:.Regardless of where the switch is set, the tach reads the same.This makes zero sense...
Try it out with all the crew & toys before thinking about props.
Can't help with the timing, hi comp frankenmotors are above my pay level.
take dremel and lightly grind lip of tach face off except for 2 spots . One on each side then bend up a lip and pop face off tach . Bend lip back over when put back together Very lightly pry up on needle. Should be fine after. I take many tachs apart . Have converted auto tach to boat ..
