FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I don't beleive so. The one I have actually burns normal oil/gas 2 stroke fuel mixture. It is just a lot quieter and seems to have more low end torque.
I bought mine online so if it was outlawed for CA, I didn't know about it.
The one I have also come with one of those Speed Feed reel. Super easy to reload. No need to take the spool off. http://www.speedfeedhead.com/
Stihl has basically the same system, except the line doesn't go all the way thru. Put each end into both holes after the arrows are lined up and turn the knob backwards. No taking anything apart. Stihl only holds about 12'. That's the downside......
Attempting to do a rebuild on our FS250 carb-the carb kit I got is the wrong one as the fuel pump diaphragm and the gasket are cut on an angle on one edge (the OEM one was square) and sucks in air.
Note to self-Take the carb with you to the saw shop so they can run the carb # and order in the right kit-----GRR-
,When I was looking for parts for the old Weedeater before I bought the FS38 I ran into the same issue.There was 4 submodels of the same model.To get the correct carb parts theres a number right on the carb.For example, ws26.
