- Joined
- Jul 18, 2011
- 18,725
I would think that 15% less flow should still allow the thermostat to make up the difference....... .........you could have some debris or sand in the water jacket around the cylinders. Mine had *some* after only 122 hrs....
Rust can mix with sand and/or other debris. This is where FORD VC-9 or Cummins Filtration "Restore Plus" might loosen and remove that stuff if it's present, then you can flush it out.
Another thing to note, based on my earlier testing of the thermostats is that they are wide open at 170. So, I can assume that the port engine thermostat runs wide open all the time whereas the starboard thermostat does the open and closing thing based on the engine load, etc.
Still not sure if the 15% difference in flow would account for the symptoms that I have been seeing, but we probably have only 1 more outing with the boat this season. Then I'll have time to go through the cooling system in October.
