- Joined
- May 16, 2009
- 9,279
Nope, no need for all that extra work as like mentioned by iboats extremely knowledgeable team members helping you out, the setup looks good...I just didn't want you to be fighting a severe engine to transom height issue only because of the beginning stages of not really knowing what the exact engine model you had due to the mixture of serial numbers along with a different designed lower gear case housing. Having the jack plate sure makes it nice should you have had to do some readjusting though.:thumb:P.S. After re-reading this and giving it some thought, some of these may need remeasured for better accuracy. Let me know if you need that and I will work out a better way.
Next time its raining and you're waiting for it to pass by, on top of the manual Dukedog was nice enough to send you, have a look around inside CDI electronics troubleshooting section as they offer some pretty good tips of how to check out the ignition systems too.:usa2:
http://www.cdielectronics.com/
Hope you get it all figured out, keep us updated and good luck.:usa:
