glennj3
Thread starter- Joined
- Sep 6, 2011
- 381
My post regarding my carburetor changed to having overheating problems so I thought I would just post a new topic regarding this.
I removed my heat exchanger after doing a pressure test that would not hold more than 10 lbs.
I do not have any pressure testing equipment here so I just filled the internal or closes system hose with water, holding both equally elevated. The levels dropped equally and water was pouring slowly out of the end of the open exchanger (end caps removed).
So to verify, sounds like there is a hole inside allowing the closed system to be open to the pickup water.
If so, is it better to have it repaired or buy a new one. This one is only about 3 years old and looks very clean.
Thanks,
Thanks,
