'05 Optimax, intermittent continuous horn problem, replaced TPS without success.
lotsip
My '05 Optimax 150 warning horn goes off intermittently, its the continuous horn not the beep type. It's totally random, might happen 5 times one trip out, then not at all the next time. Seems to occur at 8-10 mph.....horn goes off and slows me down to a crawl........don't think it has ever happened at high speed though. Service manual says its a faulty throttle position sensor or TPS. So, bought a used one on Ebay , but, the same exact issue continues. Any suggestions ?
tlh 178
i wish you luck, i have a continuous alarm. mine comes on anywere from fast idle to 25 mph. i hope i can find the problem soon, its driving me crazy!
Check oil level sensor in boat reservoir and motor reservoir. Make sure you are not overheating.
tlh 178
chris, can you give us an example on how to test a sensor with a multi meter! thanks, terry!
lotsip
I hear ya............took the boat out today, no alarm......ugh, driving me up the wall.
tlh 178
lol, i replaced water pump, impeller and thermos, plus popit value . worked great for one outing, next time out alarms. i think my opti only likes going 45 mph!
I looked at the Optimax wiring diaghram in the service manual (online), but would need to blow it up to decipher it.
However, a lot of low oil alarms come from grounding the signal wire. I would expect the low oil sensor in the motor tank to be wired to the low oil sensor in the remote tank, They should signal a low oil condition, by connecting the orange wire to the light Blue wire.
lotsip
lol, i replaced water pump, impeller and thermos, plus popit value . worked great for one outing, next time out alarms. i think my opti only likes going 45 mph![/QUOte
damn, that scares me, was hoping this would be a simple fix ! but yah, same here..........i can go slow or fast without the alarm, its just that 8-10ish speed that does it ;-(
lotsip
wouldn't low oil cause a 4 beep alarm every 2 minutes ?
I would think (think) that a low oil on the motor reservoir would slow the boat to a crawl, which is what was reported. Low oil in the boat reservoir would cause 4 beeps as would water in the fuel.
Faztbullet
Clean the strainer screen in adapter plate, if clogged it will make compressor overheat and give a hot warning(solid tone) and reduce RPM thru Guardian mode...
tlh 178
are you talking about the strainer that sit below the lower cowling on the left side on a opti?
lotsip
hmmmm, will have to find this screen.............my engine continues to run great, EXCEPT at about 8-10mph ONLY, at which time i often get continuous warning horn....its fine going slower or faster.
tlh 178
mine was clogged pretty good, only took a 1/2 hr to do it. get some locktite pipe sealer or a high temp rtv gasket maker to put on the threads. hth
