- Joined
- Mar 8, 2009
- 44,681
The timing may be dead one, but it is a very good idea to set/check timing. All you need is a timing light and a paper clip. Connect the timing light, start the motor then install a paper clip on the DLC connector between pins A and B. The connector is next to the ECM and should have a protective cover over it. Set timing at 10 BTDC
