Parts Guru needed for older Mariner
jakedaawg
Older Mariner 4hp I believe. Serial= 6EO S 025644
Need a water pump assembly including base.
The base is what I am having a hard time coming up with a number for.
Parts smart shows three different numbers depending on serial number and none of the serial numbers seem to correspond to the project motor.
Ref, No. 10. 814457M Plate, serial M-070823 ML-325783 and Above
11923M Plate, serial M-103610 ML-335564 and below
96294M Plate Serial M-055885 ML-321426 and below
My serial seems to start with an "S".
Other parts that I think I have correct:
Ref. No. Part # Name
11 27-96295M Gasket
46 27-41822M Gasket
19 96303M Outer Plate
21 47-96305M Impeller
18 96301M Insert Cartridge
17 27-96300M Gasket
16 46-96299m Housing, WP
Now, all these other parts state serial #'s that start with an M. They look correct in the parts blow up though.
Any help would be appreciated. i usually don't tackle these old mariners because I spend more time trying to
find the right parts than it takes to do the job but this is for a really nice guy.
jakedaawg
No Title
Pics
flyingscott
sorry I thought that said 40 this should be the one you need for a 4 hp 8M0080450 you are talking about the plate right
jakedaawg
No Title
Pic
flyingscott
Here are the serial # ranges I come up with yours comes up as the first one.
Mariner > 4A HP > 6E0-001011 & Up (M
mariner 6E0-300101 & Up ML
