Big_Kahuna
- Joined
- Jul 14, 2016
- 32
check the diagram. A replacement unit would come with the aphenol connector attached -- plug and play.
UPDATE: Installed exhaust cover with new gaskets. Replaced sensor coil aligned coils with locating ring. Started it up spit and sputter. Low speed needle way it so adjusted back in. Got it to run at idle until I gave it throttle. So I played with needle turning 1/4 at a time still works stall out. Haven't tried spraying around motor for rpm change will do that this evening. I guess it's to the boat man after this or sell.
Well, here's a used one that might be useful for parts (Check for fit):
http://www.ebay.com/itm/Johnson-25-...ash=item2cb0174c46:g:iiMAAOSwIgNXj5Yo&vxp=mtr
Or maybe replacement parts for your current carb:
http://www.iboats.com/Carburetor/dm/*******.454910298--**********.193802745--view_id.1537642
Presumably, your repair guy might be able to fix you up with something. Hard to say.
Lets hope it's a good one
Have to say it.---Find a good shop to repair this motor.
hey -- think you might have in hand! sounds like a little lean sneeze cold (just a little) -- my 9.9 does that too, and I adjust the carb about 1/4 richer just for starting, then adjust it back when it warms up. All good....
