BrianSmithFishn
- Joined
- Jul 18, 2016
- 26
| MERCURY | 1987 | 115 ELPTO | Model Number 1115727 |
I bought this old bass boat off a buddy for $1200 and this is the motor that is on it. It runs, but not as good as I would like it to do to his lack of maintenance. He owned it for about 4 years in college and never did anything to it besides change gear oil and spark plugs. I cleaned out the gas tank, bought gasket kits for the carbs along with new floats and valve seats. New fuel filter, and water pump kit. Is there anything else I am missing to get this running reliably? I am a first time boat owner, I do not know much about mechanical stuff but I know enough to watch videos read up on forums and turn a wrench to figure it out. Any info or help you could give me to get me out on the water will be greatly appreciated! Thanks for your time and responses in advance!
1 - What gear oil to use.
2 - What spark plug model # do I need.
3 - Any suggestions or help on cleaning/ rebuilding the carbs, leave them on or take them off? Also suggested screw settings after rebuild and clean.
4 - Previous owner mixed oil into the gas tank at I believe 50-1 is that correct and also suggested brand oil to use.
5 - Im curious about the gear box and bearing carrier / prop shaft oil seals. The health of them all. There are 2 grease fittings on the bearing carrier, Just curious proper maintenance of that whole unit. Also what ever grease fittings on the motor and the proper grease to use on them.
I compression tested the motor several times. Im getting in psi:
Cyl 1 - 80
Cyl 2 - 70
Cyl 3 - 80
Cyl 4 - 80
Cyl 5 - 80
Cyl 6 - 80
6 - Is this ok? Are they good readings, i.e. healthy and ok to run. What should they be reading at and when should I be concerned?
7 - The engine is missing the front cover with the knob and the sound seal/ blanket. I have the wrap around cover and the top piece. Is it ok to run like this or does that whole front system act as an air box to the carburetors? I ask because as it looks to me they do not run air filters or a box and I was concerned about water or debris getting in the carbs.
