CApTaInGoOfy
- Joined
- Aug 17, 2015
- 91
So I was able to install the telltale with some difficulty as the square bolt was corroded on. With the wisdom of other members I was able to get it off and installed a 3/8" brass barb fitting and a 1/4" tube. Now the issue is I have no water coming from the new telltale installation. Ran the motor with muffs on and just had what I think as the normal flow of water coming out, but bone dry from the new telltale tube.
So not sure where to go from here. When I touch the head it is warm to the touch, I can keep my hand there the whole time it is running. I've had it on the water multiple times but I do run into the same weird problem after I have it running for possibly 15 minutes or so from the ramp to the bay. When I turn the engine off, and I go to start it back up I get nothing. The motor doesn't even turn over the choke doesn't engage. It's like I have a dead battery, but I know the battery is not dead as I just got a new battery last month before putting it on the water. It hasn't been on the water since August 2015, and it was having the same issues. Was hoping it wouldn't do it again but it repeated it self.
Linked the old post I had from August 2015. Wasn't sure if I should bring a year old post back to life by posting on it again so I made a new post. Any info would be awesome, and many thanks to all that helped with info with the Telltale install!
