Thanks! I wound up getting the boat. Generally it's in good shape. I've had it out on the water for a few hours a day for the last few days and it runs strong. I don't notice a heaviness to it, but I'll definitely poke around to see if I can find any wet foam. I know there are access points on the deck that they used to fill the hull with foam. I'll try to get into one to feel it out. I almost don't want to know, because that would necessitate an entire tear-down of the boat which is way over my head.
With all of the foam in the transom area, access to wiring and mechanicals behind and to the sides of the motor is very difficult. I replaced the steering cable and it was near impossible to route it properly just due to lack of access. I'm guessing the motor would need to come out for any repairs beyond general maintenance. I definitely need to re-wire almost the whole boat, they did a pretty poor job of it, whoever rewired it last.
Today, the timing cover started to leak, so that'll have to be done. While I'm doing that, I'll also do a new water pump, and fuel filter / water separator.
Question - above the motor, mounted on the transom, there's a mounted piece that the shifter cables connect to - it has a couple of micro-switches on it. On the starboard side of that unit, there's a braided hose that connects to the unit, and then runs down behind the motor, presumably to the outdrive. If you know what I'm talking about, what is it and where do I find a replacement? The plastic coating is worn off and it's down to the actual braids now.
Thanks again! I attached a couple photos of the maiden voyage.
