rtoomey641
- Joined
- Jul 8, 2016
- 93
Hi Possible bad petronix want to try points does the wire go to positive or negative side of coil 485 Mercruiser Thanks
I guess I will be the one that answers your question....negative. I also don't blame you. I didn't put Pertronix on an engine I used to own to replace points because of the reliability issue.Hi Possible bad petronix want to try points does the wire go to positive or negative side of coil 485 Mercruiser Thanks
