jasoutside
Thread starter- Joined
- Dec 20, 2009
- 13,269
Hi fellas, I reall need some help getting this Merc to run properly. Let's start with some background so you can see what I have done so far:
This engine is a donor so these are the first trips I have see it in action. First couple of trips the engine wanted to stall right out advancing to 2K RPMs. I was suspicious of carb and dist/cap/rotor/plug wires. So, all of that was replaced. New dist/cap/rotor/plug wires and a new carb was installed.
Took her out again and she ran great through about 3700 RPMs. My WOT only got me to 3800/4000 range and that was it. It felt like missing or bogging down a little, I could just detect it. Here it was suggested I was running too rich and the carb needed some tuning. I also needed to go from the 23P prop to something smaller.
So, I spent some time tuning the idle jets. I thought I had it correctly tuned. I also swapped out the 23P for a 19P prop.
Then I took it for a run, check out the video....
It seems that my WOT RPMs are now correct at about 4800 range but at 1:35 in the video that engine is really unhappy. It starts missing/sputtering/bogging down from 4800 to 4000-4200 RPMs. I don't actually ease up on the throttle until 1:52 so you can hear it struggling between 1:35 and 1:52 in the video.
That was from a few days ago. I tuned the carb a bit more, thought I had things dialed in.
I took the boat with us up here to the big lake. Man she ran great! For about 10 minutes and then the same stuff started happening again. So I backed it down to about 3800 and she ran great for about 10 -15 minutes. Then fell off again, stalled out actually. I got it started up and idled back to port.
Well, beyond my knowledge base. So I bit the bullet and took it in to the local Mercruiser dealer up here. They have had it for two days and they can't seem to pinpoint the issue either.
They have checked over the carb, the fuel, timing...all seem to check out so far.
They are going to get to looking at it again tomorrow morning.
Suggestions? Any thoughts on next steps?
The mechanics are thinking about taking apart that carb to check it out.
Thanks in advance guys
