Boatin_in_KY
- Joined
- Jun 13, 2011
- 9
Hello, so I have a '95 75HP two stroke auto mix. I haven't been able to get it to run correctly. New impeller, plugs and fuel filter. Cleaned the oil tank. Fresh gas in an external tank. It will sometimes start and run for a few seconds (and smoke) but then die. I pulled the carbs and took them apart over the weekend and found a lot of oil in the bowls. I'm thinking its sucking too much oil, and not getting enough gas. The tank has the vent open, and holds pressure in the bulb. I do plan to also check some of the fuel lines. At this point I'm thinking of just switching to premix and seeing what happens. Anything else I should check? Is heavy oil concentration in the bowl normal? Also, any special precautions I need to take when reinstalling the carbs?
