LuvBoating
Thread starter- Joined
- Mar 16, 2009
- 718
Our boat, a 1992 20' Celebrity CC I/O is now leaking water thru the transom into the bilge area. It was noticed last Friday by the marine mechanic that installed a new (remanufactured) carb on it and was doing a "water test"/adjustment of the carb on the water. As he was adjusting the carb, he noticed quite a bit of water in the bilge area. He brought the boat back into the Dry Storage (where we keep our boat) dock and had it put on a Wash Rack. He then called me. It went down to the Shop and he showed me, on an outdrive that was sitting on the floor of the shop, where he thinks the leaking could be coming from.........the "foam" like gasket that fits into the groove around the outdrive mounting area. However, he also told me that the leak could possibly be from a rotted area on the transom. To find out for sure, he would have to take the engine and the outdrive out and inspect the transom and the outdrive to see where the leak is.
I went down the Wash Rack, took out the transom plug and quite a bit of water came out. Appeared to me that at least half of the lower bilge area (directly under the engine) had water in it.. I also seen some water dripping from one side of the outdrive mounting area and that area is rusty looking.
Due to a surgery and other things, our boat hasn't been on the water since Oct. 20, 2012. Don't really know if a transom or outdrive leak would show up when running the engine on the muffs (out of water).
Obviously, we want our boat to be safe for us, so, gonna have to have this repaired. With a new engine block installed in 2012, along with new plugs, alternator, etc., my wife told me we put to much money into the boat not to have it fixed. Have to agree with her.
So, what do you guys think this leak could be.......part of a rotted transom and/or outdrive mounting area?
