Hockeydad4-22
Thread starter- Joined
- Jun 14, 2014
- 27
I have a pre-alpha stern drive on my 66 starcraft cheiftan, 110hp 4cylinder. All original. I just pulled it as I have milky gear oil in the lower unit and figure I need to replace all the seals, might as well as do the bellows and shift rod at the same time. Then yesterday....
I was wandering through the local pull-n-pay wrecking yard and noticed a couple boats so of course I wandered over and you can guess what I see. A pre-alpha stern drive attached to a 6cyl. It looked complete, was not locked up and when I put it into proper gear, the prop that was attached would not turn in that direction.
I asked how much for the complete unit, from the transom out and was told $120 and that is everything from the transom back including the shaft. I have 3 questions:
#1 - is there a method I can use to check its condition without running the boat
#2 - is it the same as what is on my boat? mine is a 4 cyl 110 hp motor, this is a 6cyl 160 (maybe 165)?
#3 - Is it worth it? I know many here advocate replacing with an alpha but it looks to me like that will be 10x this cost and currently - that is not in the budget.
