Sea Rider
Thread starter- Joined
- Sep 20, 2008
- 12,345
It's mentioned on the forums that everybody blames E10 fuels for just about everything. Have well documented issues with E fuels as been in the transition between E and non E fuels and know the "issues" they produce. The list goes :
-Tank air vent screw doesn't screw in, seals anymore tight due to damaged threads.
-Fuel filter is very hard to unscrew from cap due to filter thread elongation inside upper cap.
-Fuel filter looks yellowish compared to a clear one as when factory delivered
-Small fuel filter small and large o'rings inside cap falls when cup is unscrewed.
-Fuel pump thin rubber diaphragm will not match fuel pump body when taken out due to elongation & deformation.
It's mentioned on every Owner's Manual that the use of E fuels will corrode metal parts, detereorate rubber and plastic components much faster along some other issues than non E fuels. Would like to know if any Tohatsu forum member has been undergoing some of these issues, if so, which ?
Happy Boating
Happy Boating
