All transom pieces removed. Doesn't look like anything that can be used as a template.
Strange setup, the bottom piece is pressure treated 2x4, the middle is plywood (may even be marine ply) and the top is also ply as noted above. the spashwell drains should have been at the bottom of the middle piece, they were never drilled. the top was just scabbed on as an afterthought for the long shaft motor.
