99 BAYLINER 2355 V-6 UNDER POWERED ?
kencobia
I AM LOOKING AT THIS BOAT IT IS POWERED WITH A 4.3 INJECTED 200HP V-6 IS IT UNDER POWERED DOES ANY ONE HAVE A BOAT CLOSE TO THIS.
Don S
Re: 99 BAYLINER 2355 V-6 UNDER POWERED ?
PLEASE, turn off the cap lock.<br />It's hard to read and is considered yelling.
kencobia
sorry didnt realize caps are yelling!
It'll probably be debatable as to whether it's Underpowered.............<br /><br />It Definitely Won't be Overpowered..........
tommays
Its the smallest motor they put in the boat so if your gonna load it up with 6 people and go water skiing you may not be to happy<br /><br />Even with a lighter load its a lot of of boat for a 4.3 <br /><br />tommays
mkast
Yes, it's underpowered. My 23 footer had a 260hp V8 in it. When the tank was full (90 gals.), six adults with all the junk they took with them the boat was like a slug. Changed to a big block.
cobra 3.0
..unless you keep the tank to 10 gallons of gas and hang around the pier. ;)
TilliamWe
Banned
Originally posted by kencobia:<br /> I AM LOOKING AT THIS BOAT IT IS POWERED WITH A 4.3 INJECTED 200HP V-6 IS IT UNDER POWERED DOES ANY ONE HAVE A BOAT CLOSE TO THIS.
If it has two of those in there, it's not underpowered! ;) <br />But yes, it's grossly underpowered with only a V-6.
KaGee
One reason why Bayliners sell so cheap. Most of them are marginally powered.<br /><br />But also consider... More HP equals more fuel consumption. There's no free lunch.<br /><br />All Depends on what you want out of boating.
I agree that it is underpowered and I do not agree that the smaller motor would have better fuel economy. For the same speed and properly propped, the bigger motor would run at lower RPM. Fuel economy would not be significantly different.<br /><br />Do you do any boating at higher altitudes?<br /><br />That boat also came with the 5.0L and 5.7L engines. I would get the 5.7L
thegodown
My bro-in-law has a 2002 2455 Classic bayliner with a carburated V8 and it is definitely under powered. With more than 4 people and gear for the weekend he can't plane without 2 bodies moving to the front of the boat.
JoJoBetsy
Underpowered. I'm guessing the best times on that boat would be sitting in it for the trailer ride home. On the other hand, a 200 horse trolling motor is overkill.
