Yamaha 150ETXJ cooling issue
HMK
I have a 1986 Yamaha ETXJ outboard that after running and at idle, one head runs about 85 degrees and the other is at 110 degrees. Is that a thermostat issue? If so, who has them? Thanks
99yam40
I would think any Yamaha dealer would have them
You can pull and replace then as Yamaha recommends or test to make sure they both work as the should. 85 sounds like it maybe stuck open if not both of them
HMK
Thanks, but there is no local dealer in the area, and I have to have them sent in. So I'm trying to find an outlet, or aftermarket parts.
99yam40
pulling them ,inspecting/testing to see if they are bad would be the best thing to do before buying new parts
mjf55
Agreed. No sense wasting hard earned money.
(seems like everything is going up except my salary :-( ):blue:
HMK
Can't argue with that logic....salary??! It's spent already, thanks.
