loco
Thread starter- Joined
- Apr 25, 2010
- 154
Hi all,
I had a pulley come loose and get badly damaged. Seems I have a saginaw pump with a four-bolt hub on it, with a pulley that bolts to it, which has a 2-inch offset, that brings the pulley valley very close to the pump itself.
So, pulley depth is 2", and the diameter is 6 1/8". It takes a 12.5mm belt.
any help locating a replacement, or an alternative that I could use. I think I need to buy a special tool to pull the hub and put another pulley on.
As always, massive thanks for your help in advance.
