hardwater fisherman
Thread starter- Joined
- Mar 19, 2010
- 1,725
Evinrude 40604R. Some history. A month ago on the lake I had a hard time starting and when taking off I could tell it was only running on one cylinder. Then it started to run on both for the rest of the day. The next time out it started and ran good first thing. But later in the day it was dropping in and out at low speed and hard starting. It would catch and go with increased RPMS. I have tested the driver coil it is within spec. I have 3 external coils that read the same and all produce good spark on top. New points clean and gaped. New condensers. I have checked all wires related to the bottom cylinder. I have tried 2 different cut out switches and the safety switch that goes with it. The safety switch works because I tried it in place of neutral safety switch and the motor cranked. The top lead jumps at least 3/8 or more while cranking and the bottom only barely jumps the plug gap in open air. I am running in a barrel right now and when it does start it is only running on top. Some times if keep the throttle on it will "grab" on the bottom and rpms will increase but if I let off it spits out the exhaust and dies. This is what it was doing on the lake but once in gear and with increased rpms it would run on both. I have had the flywheel off so much that I dont need a torque wrench, I can do it by feel. EDIT I should ad I have new plugs gaped at .030. Also new high tension leads, boots and the little spring things that fit over the plugs.
