littlebunker
Thread starter- Joined
- Dec 6, 2013
- 33
Hi all, I was just told that I ought to pick up a water separator. I've never heard of this particular piece of equipment but it was described to me as essential. I don't boat much but I have a 12gallon tank, so I probably only fill up once a year.
Thoughts on a water separator? I have a 30hp evinrude that uses one of those primer bulb fuel lines. The water separators I'm seeing look like you basically run it inline with the fuel line... like right now, I have the evinrude fitting on my gas tank and the fuel line comes right out of that. Looks like maybe I run a fuel line out of my gas tank, and into the separator, and then attach the evinrude fitting to the output of the separator. Will these separators work with the primer bulb fuel lines, or will that make it too hard to suck out fuel?
thanks!!
thanks!!
