69starcraft
Thread starter- Joined
- Jul 11, 2007
- 169
I've got a friends boat here in the shop I am trying to help out. I do some work on outboards, but confess I know little to nothing about I/O and particularly Volvo.
I replaced the Shift Cable for him last weekend...was surprisingly easy or I wouldn't have taken on the job. Finished up and everything was fine.
He took the boat to the lake, texts me and says it won't start. Brings it back to me.
Battery was low, so I charged it up. Fired up boat and everything seems fine... no issues
Until I tried to turn off the boat.. She won't shut off. Turning the Key switch to off, or even removing the key, does nothing... the Gauges DO turn off, but motor continues to run.
Also the emergency Kill lanyard does nothing now. If you pull it motor continues to run.
Finally found a relay in the box on top of motor that when pulled shuts the motor down...no idea what that relay is for.
The internet has been little help in finding a diagram or schematic. The "map" on top of the relay box is confusing to say the least and I have no blown fuses.
Have been trying to read up on it and found a post suggesting to remove the purple wire from the alternator and test again...same issue, engine continues to run.
My gut thinks that the ignition switch itself may be bad, but again the gauges do turn off, and even with a bad ignition switch shouldn't the safety lanyard switch still kill the motor?
At a loss here and could use some help
The boat is stock, in excellent shape...no wiring was hacked or messed with ever.. All I did was put a shift cable in it... was operating fine prior. still does other than not being able to cut off the engine.
Boat is a 2007 Glastron GT185
Volvo Penta GL 4.3 motor
SX-A 1.79
3883623 is the number on the outdrive...
Unsure where to find engine numbers...
Any help would be appreciated...
Google was worthless....tons and tons of boats "won't start" but posts about boats not stopping not so much
SX-A 1.79
