Mercruiser Bravo I Cooling Questions
tank1949
Motors appear to have pulley pumps but I cannot see any sea strainers. Former owner said water comes via ODs. I assume no strainers... Should I install one?
Usually no strainers unless you have closed cooling. Do you have closed cooling?
What kind of issues are you having?
tpenfield
Motors ? Twins? New-to-you boat?
Yes, the water comes in via the outdrive as powered by the sea water pump. As stated, strainers are not standard issue, but can be added. I have added strainers to all of my Merc/Bravo engines. It keeps the impeller and cooling system in good shape.
Fun Times
Sea strainers.... Should I install one?
What type of waters do you mostly plan to boat in? If the water seems exceptionally sandy then strainers should be considered. Also does the lower gear case housing have lower or dual water pickups that could easily pick up more sand in shallow areas. Some of the bravo lower water pickup holes sort of resembles the image below at the nose cone area.
thumpar
My B1 has the side intakes. There is no strainer on it. The water that I boat in is pretty clean except for some weeds in the shallows. It has never had an issue.
