oem or after market manual?
sorry chris, but ya got it totally wrong... its done with idle timing screw.. tha merc carbs have an "idle circuit" that it runs on.. throttle cable/stop screws should not be used for idle speed ... this is straight outta tha book..
IDLE SPEED ADJUSTMENT
1. With engine in water, connect fuel line to engine. Start engine and allow to warm up.
2. Place outboard in gear and monitor engine RPM. If RPM is above or below recommended RPM (see specifications), readjust primary pickup (a) screw to attain recommended engine speed. Retighten jam nut.
a
CAUTION
Engine idle RPM must NEVER EXCEED 750 RPM
this is done after a link and sync is done and/or confirmed to be in tact.. if idle was all good then it changed ya got something amiss and will need ta be tracked down.....
