syuhas85
Thread starter- Joined
- Jul 30, 2011
- 37
Ok, I have a 1989 Carver which has a 7.4L Bravo 1 serial is OC663010
I can not for the life of me figure out how the Belt comes off the sea water pump i purchased a new impeller and would like to install it.... Everything on the engine has a belt tensioner besides the water pump, the newer style 7.4L have a Idler pulley that you can use to take the belt off.
this 7.4 is a belt going from the sea water pump to the crank and it has tension on it but i cant loosen it up to get the belt off there is 2 bolts above the pump holding it to the engine block and another long arm holding it to the other side of the engine thats it no slide no tensioner im lost lol... do i just pry the belt off? I found a image of a engine I posted below you will see its the same engine sea water pump has belt going straight to crank.
