kramerpage
Thread starter- Joined
- Jul 26, 2010
- 447
I do not have rising battery voltage when the motor is at 1000 rpm and above.
I believe my first step is to check wire integrity from battery + to starter solenoid. From there to the pair of red wires to each voltage regulator. The pair of yellow wires going to the stator. Just to look for corrosion. open worn wires and what have you. Oh also grounds on the regulators.
If all is well I will go to check the regulators per the shop manual. which leads me to MY QUESTION.
What if only one regulator is found to be bad? So does each regulator have the ability to distribute 20 amps each to the battery as needed?
Thanks
Thanks
