I recently bought a 1990 Maxum 2150 that is in exceptional condition except for the hydrolocked 4.3L Mercruiser engine. I have a running 4.3L OMC engine sitting in my garage from a recent rebuild attempt to a Donzi hull (I quit once I found the Maxum).
I got the engine out of the Maxum this weekend, started tearing it apart (it already had the heads and intake off) and verified that there are multiple bent piston rods.
My original plan was to swap all the Mercruiser stuff over to the older OMC engine and drop it into the Maxum, but I'm not sure if it is going to be that simple.
So here is what I'm working with and I would love some advice!
The hydrolocked engine was a new crate engine a couple of years ago and has around 40 hours on it now.
12600234 block
12557113 heads
12550460 intake
The running engine was supposedly rebuilt a couple years ago after freeze damage and has around 100 hours on it now (but considering the previous owner, I'm taking that as worth a grain of salt). It seemed to run fine for the couple of hours that I used it before I pulled the boat off the water due to structural issues.
10227196 block
0238181 heads
6269732 intake
My big issue with running the rebuilt engine the way it is, is it (from what I've read) does not have vortec heads and is a 12 bolt intake/2 barrel carb. I'm afraid it is going to be under powered for the Maxum. So I'd like to swap the vortec heads and 8 bolt intake/4 barrel carb over and enjoy that extra power (though probably still a little under powered for the size of the Maxum). If I do that, do I need to replace the rocker arms and pushrods (all those parts from the vortec heads are sitting in a box so I can't put them back in their original spots)?
I've had a couple people tell me to just replace the bent connecting rods and run the hydrolocked engine (assuming the cylinders and pistons are still in good shape).
12600234 block
12557113 heads
12550460 intake
10227196 block
0238181 heads
6269732 intake
