mjf55
- Joined
- Jun 17, 2014
- 462
As the title reads, I have a 1989 Yamaha 175 ETXF that I am replacing the prop shaft seals. ( I already replaced the driveshaft and shift seals). Everything I read shows there are 2 seals to replace on the prop shaft. However, when I removed the first one, there seems to be a metal ring spacer and only the 1 seal.
Because this is a salt water boat, I am trying to remove / replace the seals with the shaft on.
Here are 2 photos of the carrier, with the seal ( 1) removed. Can anyone advise me? ( I really dont want to remove the carrier from the LU, as I know something big will break.
