The last two nights after work I have worked on getting my 1994 alpha drive 4.3 winterized (2 barrel version) for the first time. I've changed the oil and filter, fuel/water filter, plugs, wires, cap, and rotor. I pulled the 2 drain plugs off the exhaust manifolds and 2 lower ones off the block. I pushed a wire up inside of all 4 and found some debris in the port side block drain that allowed the water to pour out rather than trickle, the others were all clear. I want to be 100% sure all the water is out, what am I missing or what more can be done? I would imagine there is still some water inside the water circulation pump, is there a drain or do I just pull a hose? Water in the T-stat housing?
Also, leave drain plugs out and tag the ignition switch to reinstall in the spring, or put them back in? I was thinking with them out air may be able to get into the passages better and dry out and moisture and/or give a place for water to escape that may still be trapped in there when the boat is parked with the nose up for the winter....
