Re: 1978 OMC 120 / 400 Stringer Tilt Motor replacement
Hi guys, I've got some more info...<br /><br />1) I have a bolt-through motor. I can't fathom how it's supposed to come off without removing the intermediate housing. The bolts are in such an awful position located behind the bell housing area that I can't reach them in any meaningful way to remove them. I'll try again, but if it's got to come off, it will probably be when I remove the intermediate housing.<br /><br />2) I managed to get the tilt quadrant off and move the motor into a tilted position. The motor is not moving freely at all. I did manage to get some grease into the zert fittings, but only one of them seemed to take the grease. It's going to require some work to get the motor moving freely. I will follow the steps Boatist suggested.<br /><br />3) The gear does not move freely at all. I removed the snap ring and the gear wants to come off, but the clutch and housing will not come out. I pounded it with a hammer (firm but not hard) but no dice. Am I supposed to remove something else? I see in my manual that the worm gear area might need to come out in order to allow the clutch to be removed, but I can't see how to get it to come out (that area behind the triangle-shaped piece of metal). <br /><br />Ok guys, what next?
