icuOklaCity
Thread starter- Joined
- Oct 27, 2016
- 7
New member and new owner of a 1956 Evinrude 15hp Fasttwin...
I have zero history on this motor... I bought it from a younger guy and his wife for 50 bucks... He didn't have any information on the motor as he had never seen it run. It was giving to him when is grandfather pasted and didn't have a need for it...
The motor has good compression, spark and looks as if it was ran completely out of fuel as I can't see any lacquer in the clear fuel bowl...
There is a good amount of gear oil build up on the lower unit and prop. The prop shaft turns freely and gears seem to be in good shape. Not much Gear oil left in it, and it differently will need a seal kit.
I also got the orginal fuel tank and was supprized on how clean the inside was. Motor has not had a fuel pump mod to move it from 2 line to 1 line system..
I have replaced the spark plugs, and basic cleaning of build up oil and grim... Washed out fuel tank to remove any thing I couldnt see that might have been in the fuel tank.....
I don't see any reason why this motor shouldn't run once I replace the old fuel lines.
I just have a few questions....
First, is there anything that I need to do, or should know about before I try to start it...???
Should I convert it from pressureized tank 2 line system to the 1 line "fuel pump" system...???
Also on the fuel tank, there is a fuel line coupler that has 2 small "pins" 1 on each side of fuel line. Is there a special coupler that is needed to run the fuel lines from the tank to the motor. Those "pins" push in like they might open some type of value when the fuel lines are connected...???
I'll post pictures of fuel tank coupler if needed ..
Thanks..
Thanks..
