I recently installed a new longblock SBC ( 5.7L) from large engine distributor ( center state) naps replacement for 5.0GL and it has about 5 hrs on it so no full throttle yet. I changed oil and cut part filter and all looked good. But for grins checked the compression when cold and it's all over the map, ranges from max of 170 to low of 95. I sprayed a very small squirt of wd40 in that one and it rose to 100. The engine vendor recommended checking valve lash at 10 hrs, which I thought was odd since it's hydraulic and roller cam. I "may" hear a funny backfire sound thru exhaust at idle (boat has stock thru prop exhaust) but honestly might be my imagination. Is it possible some valves are slightly tight? Am I over thinking this since it's so new ? I wonder if I can get valve covers off with exhaust in place ( all stock vortex volvo penta drivetrain) . Then decision is to do it messy way now hen running or try to turn it manually. ( has crank mounted sea water pump so that needs to come apart to get to harmonic balancer.
