Cracked and soaked fiberglass motor mounts on Sea Ray 200cc
ripazka
No Title
Today I bedded those bad boys in.
ripazka
That's exactly how mine was. Totally different boat now. This thing is more solid than its ever felt to me as the second owner.
I cant wait to see how it acts on a bigger waves now. Im pretty sure there is dramatic difference!
Also the correct engine alignment and correct transom thickness as well as healthy transom wood may help a bit :D
ripazka
No Title
Fillets done. Next week: tabbing and maybe start of capping.
ripazka
No Title
Today I made those extra side wings from scrap plywood sheets. After that I sanded everything for tabbing. Tomorrow and after tomorrow Im gonna vac the dust out, glue those wings in and cut woven!
bjf66
ripazka
nice job looks a lot stronger now with additional wings
having spent 2 weeks travelling through asia I missed working on my own boat and not catching up on progress on others as cant get the iboat webpage in asia, now home for 2 weeks time to continue the project once more
ripazka
Today I fixed some minor hairline cracks outside the hull. I am so happy I chose epoxy for my project. Even the small amounts of gelcoat smells inside the house.
Ive been busy with cutting the woven for tabbing. It takes ages but Im moving along! Im catching up my schedule and my plan is to be ready late of May! My biggest challenge is the deck because I still havent found those thin foam sheets here in Finland.
Baylinerchuck
Yes poly does stink, but honestly I've gotten used to it. Just a little forced ventilation goes a long way!! I think the gel coat is much more smelly.
ripazka
No Title
Woven 100% precut for tabbing. Gelcoat is kicking veeery slowly. I placed a hot air blower to garage. lets see :D
Baylinerchuck
For some reason with the gelcoat I'm using, I have to add some heat to get it to kick as quick as the resin. I use it at the same percent MEKP which is about max for the temps in working in. I haven't had a problem since heating it up some.
ripazka
Thanks Chuck. I ordered new batch yesterday. It just didnt kick in.I swiped all out with acetone. I even mixed 4% mixture and placed it on warm surface. I Used peel ply to one area and hot air gun to another. There was enough temp, humidity was about 35%. Still nothing... Ive never seem this problem before. Im gonna call them today. Weird
Anyways, I hope I have a bit shorter work days this week so I can start tabbing! Cant wait to get ready with the stringers and bulkheads. ;)
Baylinerchuck
The one batch I made up with surfacing wax actually kicked quickly without heat. Maybe try a test with wax added, or cover the test sample with plastic to keep the air out and see what happens. Who knows, maybe the stuff you bought was over a few months old. Poly definitely has a short shelf life.
ripazka
Must be something with the badge. Well lets see when I receive the new one.
Today I put fillets to those two extra sidewings. I also started tabbing, maybe 5% done. I had only 45minutes. Im planning to tab the rest during this week. I already planned to have Friday off ;) Next month Im away for a week or two. This time in Illinois. If im lucky I may see some US boats in lake Michigan!
ripazka
20% tabbed in. Ready with it on Friday I suppose. Couldnt get any nice pic for you because the cabin was so dark. Will send a pic on Friday. Im very pleased how this woven settles!
ripazka
No Title
What a task. Took about 10 hours from start to finish. Tabbing is DONE! Capping during weekend if I got enough time. Progress!!!
