Need help trying to figure out motor year
Mballo21
Trying to figure out what year motor is it's a mercury 850 thanks
Looks to be a 1977 with replacement powerhead.--------Picture of cowling helps.
Mballo21
No Title
Hope that helps thanks
GA_Boater
The disc for the powerhead and the transom clamp for the rest, if the transom clamp isn't a replacement for a broken clamp.
In other words, you may be asking more questions.
GA_Boater
What year is the powerhead? Decals don't work for that.
I would say powerhead is 1984 rated at 75 hp.-------Is there a date stamped on the starter ?
GA_Boater
That's what I came up with too, Racer. But sometimes I pick the wrong up the wrong number.
The dated starter is a good way as long as it's original to the powerhead. No guarantees with Frankenmotors though.
jimmbo
The Transom/Swivel bracket is pre 1984 for sure, might be earlier than that as it still has the clamp screws
Post number 2 is probably close, if not dead on
Mballo21
K I'll get a pic of the starter this afternoon any other pics that would help just let me know thanks for everybody's help so far
Fun Times
Technically speaking with Merc, the cut off date/month was either June or July 1st (can't recall exactly at the moment) for the transitioning into the next model year for production... So with the starter saying 7/28/76 should still mean the original outboard engine to be an 1977 model year.
The power head appears to have been changed from Mercury to Mariner evident by the number found on the welch plug but appears to still have used some of the Mercury's original components evident by the starters date.
Mballo21
Don't know if it matters much but it is a 4 cylinder so which one of those numbers would be the serial number I can't seem to find nothing when I try to look those numbers up
???------Well one is the serial # of the original motor.---------The other is the serial # of the motor that the replacement powerhead came off.-----------------This stuff is the same for many , many years and parts interchange.-----------Replacement powerhead is EXACTLY the same as the original.
Mballo21
If I go to mercury parts catalog and type serial number 06560616 it comes up with this MARINER 75 ELPT
Well I am not sure why you are asking for more identification help here.---------A Mariner motor is a Mercury with a gray paint job !!!
