Identification
Nwbassfishin
Picked up this boat from a yard sale, no Title.. So I am trying to gather information on it. Ive looked on through multiple post on iboat and hours on google. No luck. Only marking are on this plate and nothing else on the boat its self. I mainly want to know the year
Valley Aluminum
Valco
517 "P" st fresno, cali
502370
without a title, you may have the yard planter model.
Starcraft5834
it should have a hull ID # of sorts on it.. if you dont have a clue on the make, you can probably pick the make... ie- on titling forms... doubt the titling agency in your states is going to have a clue as so many different manufacturers.. you generally fill that part in.... as long at you have the right ID # your probably good.... call it " NWBASSFISHIN":eek:
jbcurt00
It a Valco, as posted in the OPs original post, and likely doesnt have a HIN as its probably pre-1972
Nwbassfishin
No Title
this is the only information i found...
Nwbassfishin
No Title
A couple of pictures that i have... might be able to help..
southkogs
You can look around a little bit HERE. I'm guessing from the SN that it's older than the 70s so it probably doesn't have a HIN.
Welcome aboard.
The floatation boxes and seat frames are missing. I would be replacing those as they are the structure that holds the gunwales together as well as the floatation for when the boat turtles.
Nwbassfishin
Thank you, i will be restoring the boat... I will start a thread when I'm ready...
