Watermann
- Joined
- Jan 12, 2013
- 13,834
You have to seal the wood. Helmsman Spar is what most of us use in the formula... I've gone to painting the transom and the inner Al transom skin it sits against. I use an oil based poly alkyd primer and then the same in a tractor / industrial paint on the wood and the base AL gets cleaned well, self etch primer and then paint.
On the windshield weather strip, yeah that's what I used on my SS between the bottom frame and console. If yours was a vinyl piece I don't know where a replacement would be, most of us in the Starcraft world improvise as the old stuff is NLA. EPDM rubber seal I posted worked for me.
Vinyl rubrail insert, do you have a piece of your old one to compare? We old Starcraft guys buy ours from Wefco Rubber. 0101G is our SC profile, be sure if you find the correct profile to add it to your thread here so the next guys know what fits for sure.
http://www.wefcorubber.com/PDF/marine/Rub-Rail Inserts.pdf
