bellsinaboat
- Joined
- Aug 30, 2016
- 16
Well we finally got the boat apart. Got the cap off, removed the flooring, stringers and wet foam. We found old patch work under a stringer on the port-side in bad condition. The glass is delaminated on the edges and brown (clay-looking) caulking? is crumbling. That area is so weak that you can punch through it with a finger. My questions for the repair are:
Do you recommend using vinyl-ester resin instead of epoxy resin for the inside reglassing since we will have to repair gel coat underneath?
What do you recommend for the repair of that area in general?
