proshadetree
- Joined
- Jul 19, 2008
- 1,887
Wow that thing has been modified a few times. I would really mark the holes i was going to reuse. Are you going to fill that keyhole up some?
Small fan with a dryer hose lead outside helps. Look at bathroom vents.
Not as bad as a big fan. Put a cord on it so you just plug it in and put it close to the repair. Run the hose outside mostly resin stink going out as they are low volume fans.
12 box fans sammiched in the garage door then block off whats left with plywood and woosh![]()
