Serial number Problem miss section very very hot
My sticker says OT080686 in serial box and the box under it has 2000 8M and year says 99. Why when I go to any mercury sites trying to order parts the sites tells me no serial number found.
Miss section of the motor is too hot to touch after 2000ft wide open... but the water coming from power head is still cool maybe 20 degree warmer than the lake water...ready to drop this motor in the lake and by a 20hp honda 4 stroke.
Fun Times
Your serial number comes up fine for me.. Sometimes you have to put a number 0 instead of a letter O at the starting of the serial number while doing a search.
MERCURY
2000
8 Manual
Model number 1008201WD
6/8/9.9/15 HP < For a different parts catalog option, you could also search the Model number online now that you have it.
Here is iboats parts catalog for your engine too, http://www.iboats.com/MERCURY-8-HP-1...iew_id.1701321
I've tried iboat and XXX.XXX and received the message in the screen shot.
Fun Times
Unfortunately iboats doesn't have an area to input OEM serial numbers to do this search. The system requires other methods to find your engine model but trust GA_Boater and I that the parts link provided is the correct parts catalog part number for your engine model... (PARTS MANUAL Part # 90-803024 covers engines 6/8/9.9/15 HP.
