For you Harbor Freighters.........
Craftsman went overseas in the 80's. Holochrome and Danaher made some tools, Stanley made others.
StarTed
I've used a variety of HF stuff over the years. Some of the stuff is pure garbage and other stuff seems to work OK. I pick up a 4" angle grinder for 10 bucks and it lasts a few years for light duty work then replace it. Air tools seem to work OK for light work. Welding wire can be a good buy when on sale and works as well as the name brands for me.
I also use their drill bits. It can be entertaining with some of them because they can wobble or untwist if getting caught. Most of my use of them is in the drill press at low speed. It amazes me how well some of them can drill many holes in stainless steel before getting dull. Then I just sharpen them a few times by eye and drill more holes. They're cheap and seem to last almost as long as high quality bits if used carefully and with cutting oil when drilling metal. I keep large numbers of the most common sizes that I use. 1/8" gets the most use because it's my favorite for pilot holes. I also buy quality drill bits and they break more easily but seem to hold an edge a little longer. It's worth keeping a cheap set around for use when you want to save the quality ones. Drilling abrasive material ruins any drill and plastics dull all the drills in a while.
I've also seen name brand hand tools there. They've carried Channel Locks as an example.
I've bought several SDS drill kits from them but they don't last very long when using them to break up the hard basalt I have In fact that is where the extended warranty pays off.
I'll visit HF again.
MTboatguy
Yup, Craftsman has not had their hand tools made in America for quite a long time now. I am missing 1 wrench to have a complete set of American made Craftsman wrenches and I look and look, but they are getting to be like gold for what they want for them!
That said, I also have some Kobalt stuff as well as Husky stuff that are both made by the same company that makes the Craftsman stuff these days.
WIMUSKY
All I've owned is Craftsman wrenches, sockets etc. do they still say USA on them? I know I have stuff that was purchased since the 80s. They all say "forged" or "made" in the USA....
Baylinerchuck
HF wrenches also are great to keep around for that "special" custom wrench you need to make. I don't feel bad modifying an HF wrench with a blue wrench or saw to make it fit in a tight space.
gm280
I have at least one complete set of Craftsman sockets and extensions and ratchets. Problem is, I bought, decades ago now, their Craftsman stacked tool boxes and their inserts for those tool boxes. The funny part is their very own inserts have places for sockets that Craftsman has never made or offered. Odd sizes that I can't find anywhere. And believe me, I have looked and been looking for years to fill those holes. Sizes like 21/32" and 25/32" 6 point 1/2" drive standard sockets and 19/32" and 25/32" 12 point standard 1/2" drive sockets. They have holes for such sockets in their inserts, but I have never seen any available ever from any source. :noidea:
I have 1/4" 6 point and 12 point in both short and deep well sizes as well. And the same for 3/8" and 1/2" drives too. And then backups for those as well. Almost every tool I own are older Craftsman and I do wonder what is going to happen when Sear finally closes. Because I too see that happening pretty soon.
I know a lot of folks have gone to Kobalt and Husky and the likes, but if you compare the wrenches, you can see the older Craftsman are built from superior steels. There are thinner and able to get into smaller areas then Kobalt and Husky and similar wrenches just can't by their larger thicker designs.
I also see how Craftsman quality has changed over the years. Their once quality ratchets use to be all built from metal. Their newer versions use plastics in the ratchets now. Look closely at the flip blades and see plastic to change from one direction to the other. Sad. JMHO
Grub54891
I had a pair of Sears vice grips. They broke, and I took them in for replacement. No-go. The claim that it has to say craftsman on them. Well they are sears/craftsman store but they refused. I also have Craftsman vice grips, but the labeling is printed on them comfort grip handles----Which is wearing off. I wonder if they will replace them if the logo is gone?
MTboatguy
According to the story, the ratchets, sockets, and wrenches are made in China which started in 2010. The rest of their tools are made in the US.. Apparently, everything I have is pre 2010...... None say China...
Wim, if you run into them, you will know it because they say China on them, one thing I have found with many of the Chinese hand tools the metal seems to be more brittle than the American Made tools, last winter I was replacing a bolt on my plow and tugging on it with one of my Kobalt wrenches from Lowes and that sucker snapped and sent me flying! I was putting a lot of force on it and it was cold but at least the snow was soft when I landed!
:D
WIMUSKY
I need another breaker bar, actually 2. So, I'm going to snoop around and see what's being stamped on their tools.....
Pusher
I will do my best to never buy an air compressor that small.
Harbor Freight has great prices on their breaker bars and their step drill bits. I've also had good luck with thier drill bit sets.
I got the 20% coupon so I might go down for a tarp and drill bits.
By the way, everyone should know that their angled duckbill pliers for a couple bucks are EXCELLENT for plucking those nose hairs. Just rifle through the plier bins until you find a pair that meets up flush well. Best purchase I've made yet. Nothing like the smell of a shop tool while ripping the extras :-D
fishrdan
HF isn't bad for consumables, but I won't buy a power tool there unless it's going to be a 1-use thing. I recently bought a set of sawzall blades for metal which worked well, much cheaper than Lowes. I always check the tool before buying it as some of them can be hit and miss. IE: if buying clamps run them up-down to make sure they work properly.
It will be interesting who even carries(buys out the name) craftsman once Sears goes belly up.
I've seen Craftsman tools carried in Ace hardware stores the last couple of years, which I thought odd as Craftsman used to be a Sears exclusive brand.
I have a pretty good selection of Craftsman hand tools from 20 years ago, and can tell the difference in the stuff they sell now. I picked up a 15-20 piece Craftsman screw driver set for $15 while Christmas shopping. I should have looked it over better as the set is real goofy, #1 Phillips stubby screwdriver instead of a #2 and the shafts on the screwdrivers are not as thick as the older ones. I got what I paid for...
Gyrene
True.
I believe the exclusivity went away after KMart bought Sears - right after KMart was bankrupt.....
dolluper
My 40 year old craftsman torque wrench racket wore out..lifetime guarantee wore out also they say Humm ..bought a new one elsewhere with lifetime guarantee. .China made now you guys says See you Crapsman
I had a Craftsman torque wrench when they were still made in USA...piece of junk.
