BlueandGreen
Thread starter- Joined
- Dec 30, 2016
- 6
Hey guys, I'm new to the forum but have been reading on here extensively. Bought a 1990 Celebrity 180 4.3 mercruiser with Alpha one outdrive in December 2015 and set to work restoring her.
The issue I'm having is that she will idle and accelerate fine, decent hole shot, and getting up to about 35 MPH at 3500-3700 rpm at 3/4 throttle, but then wants to bog down if i push the throttle any further. Runs and handles fine. Doesn't bog down in turns. Pulls a tube or skier great. Gets up on plane fine. Just won't get to WOT or as fast as she should. Wondering what is wrong.
Here is what I have done:
Completely rebuilt interior including floor and all seats,
Rebuild top half of engine:
New valves and springs, resurfaced heads, new marine head gaskets, new plugs and wires, new intake gasket, rebuilt carb, cleaned and flushed gas tank, new fuel filter, new electric fuel pump and new fuel lines, set timing properly at 8 degrees before TDC, checked compression on all cylinders (within 10 psi), new oil in engine and lube in outdrive. New main bearing, all new bellows, and new lower shift cable. New cast iron exhaust manifolds and gaskets.
Prop is a 14 1/4 x 20, 3 blade stainless steel. Came with boat, looks like it was dented on the edge and hammered back out at some point. but runs without any chatter.
Any thoughts or help would be greatly appreciated. Thanks guys!
