1950's Wagemaker Wolverine wooden boat restoration ...
sphelps
Oh btw, I tried the iron with the wet rag trick on the depressed plywood spot on the transom ..
Actually worked pretty well .. Didn’t take all of it out but it did take a good bit out ...
sphelps
A lot of contrast after the 2 part bleach .. It has to be sanded . It darkens up a good bit after sanding .. 4DEE3A70-65B3-479A-A15C-55487A9677EE.jpeg
That is after sanding and and just wiped down with a damp cloth on the right .
sphelps
Picked up a piece of mahogany on the way home today . 5 board ft for 40 bucks .. I have to replace a couple of those seat base bracket thingamajigs and cut a few more plugs ..
Also the sil got me an early Christmas preasent .. His uncle was getting rid of this new scroll saw for a 100 bucks ...Been wanting one for a while ...
zool
Yeah, mahogany can get expensive, but that looks like a nice slab....and a brand new dremel scroll saw cant be bad either!
Ned L
She’s looking very nice!
(my personal .002, I would agree with nothing in the foredeck seams.)
sphelps
Thanks guys ! I’m really hoping to have this thing varnished by Christmas or at least started on the multiple coats by then ...
buxmj
Looking great Sam, wish I were closer to help out, love working with wood and regret my wooden boat was too far gone.
Buck.
zool
Every once in a while the easier route wins out.....caulking seams is a tedious job! Looking good Sam!
mickyryan
I see reason not to caulk as well but I had to say previous thought at a attempt to instill doubt and help you lie awake at 3 am wondering with anxiety and a mountain of indecisive thoughts :)
sphelps
LOL ! Micky I don’t need much help being indecisive! I do that all by myself ..
If the planks were wider AND there was a solid band of wood around the edge of the bow to contain the planks I would most definitely be caulking the joints .. ;)
‘And talking of indecision.. Everytime I’m out there the debate in my head is to stain or not to stain . Like there a little Sam on each of my shoulders each trying to sway me one way or the other :boink::whip:
After all this work the last thing I want is to screw it up ..:twitch:
zool
What are u worried about?, if u dont like the stain, just sand it all down including the corners and crevices, then wood bleach the holes again and maybe replace all the plugs :eek: :D
chevymaher
So what your saying nicely is it is the same amount of work as replacing the foam under the deck on my boat.
make a test board with a few strips of mahogany, etc with plugs. stain one half, dont stain the other. that way if you dont like it, you only made an expensive conversation piece.
