- Joined
- Jul 23, 2011
- 52,138
if you look at a repower, I would look at the VW(Audi) 3.0 marine diesels
Runs fine until warm them sputters and dies and basically won't restart(but it wants to) until cold. I thought it was fuel and replaced filter, fuel pump. Can see gas squirt in throat when I move throttle. Starting fluid doesn't help. But what does seem to have fixed it is removing the PCV valve.
Need to find out when it doesn't start IF you have spark. Pull the coil wire and see if you have spark, suggest a spark gap gauge.
You can spray either (starting fluid) and nothing happens, leads me an electrical issue. Do you have points and if so have those and the condenser been replaced?
Removing the PVC and it starts would push me toward the engine flooding
Don't know if I mentioned this but it sputters when it dies, then surges a few times and finally dies. I would think that a spark failure would be an abrupt failure, but I dunno.Need to find out when it doesn't start IF you have spark.
