Firebolt420
Thread starter- Joined
- Aug 21, 2012
- 42
I am in the process of installing the controls and I have gotten to a point of confusion. I have a '87 Mercury IL6 115hp using the Quicksilver Commander 2000 controls. When I had everything apart I got into the controls to replace the tilt/trim switch. In doing so I found out too late that I could have done that without complete disassembly.
So flash forward to installing it and even though this is the control that was connected to the motor before and I taped the adjusters but the throttle will not extend far enough to reconnect when the motor is throttle closed or when connected the throttle does not back down. Since I took this all apart I haven't made any adjustments or changes on the engine side. I am to the point of getting ready to pull everything apart and see if there is something I am missing or clean everything up and take it in to have a pro take over.
