bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
I have a 1999 Johnson 150 hp and I am using an OMC side console control. I have taken the boat out about 5 times and the shifting was fine forward and reverse...all of the sudden this past Saturday the motor would not shift into reverse...is would just grind gears.... it was like it wasn't shifting far enough...but it was all of the sudden... the adjustment rods on the side of the motor...were tight...I don't see how they can rotate while clamped!! so I unclamped that bracket and turned the adjustment to get more movement to reverse, and it was shifting good again into reverse as well as forward. then a few hours later it seemed like I was grinding a little goijng into forward!!!!...but the grinding goes away if I shift fast.....but it didn't do that before the adjustment and right after the adjustment...so my question is.....is it possible the culprit of my issue is really inside the control?... are there parts in there that wear and go bad that could give me the issue I am having? its more of a pain to remove the control and tear it apart and look inside....so ill ask here first.......
bob
bob
