I need some help with soldering
You know, someone comes up with something new all the time. That might not provide the technically proper connection, but I just bought 25 of each of the yellow and blue. If the solder will flow with a heat gun only I think they could work for boat and or trailer stuff.
They will sure work better than the crimp types.
They have been around a long time.
What makes you think they would work better than the crimp types?
Personally, I would solder wires together and cover with shrink sleeve before I used something like these.
lmuss53
It would seem that they have been around a long time, I guess I'm late to the show.
I think that any properly flowed solder connection would hold better that even the most tightly crimped butt connector. I have seen many of them fail, often because they weren't used properly, but I can't remember seeing a soldered splice fail. So, like I said, IF the solder will flow with the heat gun...they will work better than the crimp types.
My current splice method is to solder wires like I described above and cover with a sleeve of marine shrink wrap with the hot melt glue inside. I'll try these and see how well they do, if they work they will speed up a process that takes a good bit of time to do when it is not done at a bench.
One would think that but the problem is the soldered connection will fail because of bending and vibration fatigue before a crimped connection would fail. One of the reasons, soldered connections are not used in a commercial environment. For example, you would never do a soldered ring connector on an aircraft.
Those solder connectors have been around a long time...20+ years but never used in production.
Grandad
It's been a standard requirement in both CSA and NEMA standards that ground connections depending upon solder are not permitted in building construction. As I understand, one concern is that as a wire warms while carrying excess current, the join can fail, leaving a device un-grounded and "alive". I'm a little surprised that naval guns would depend upon solder connections, but I'm sure there's a lot of engineering and quality control in military procurement that probably ensures a durable connection. - Grandad
gm280
Yes I would say you have clean up work ahead of you. I would cut the leads to the proper length and attach connectors on the ends and then wire tie the wires in a nice neat order. Then future wiring issues would be very easy to fix. JMHO
Strangeleak
Bruce
I would prefer these solder connectors over a crimped connection as well.
And your preferred method is not much different than what these tubes provide.
My method: I heat up each end of the shrink first and allow it to collapse and briefly cool and adhere, for a few seconds, around the wire insulation, it creates a pocket in the middle. As the solder begins to soften, the shrink squeezes it around the wires and it starts pushing a little solder out each side evenly (if held parallel to ground). As it cools, there is a "ribbon" of solder from one end to the other that strengthens the entire tube. The stress of the joint is no longer on just the wire/solder, the tube and wire insulation are now part of the equation.
Shrink tube + solder + adhesive creates a near perfect, water/weatherproof connection IMO.
Bruce
Actually, my preferred connection is a crimp using a quality crimper and a quality crimp that has adhesive in it like an Ancor especially when doing something like a ring connector which hasn't been discussed here.
lmuss53
I used some of these solder ring connectors Sunday to put in a bilge pump. All in all I'd say they are no better or worse than a crimp type. I put a dab of flux on the untinned wire and heated them with my heat shrink gun until the solder flowed, which required a lot of heat from the gun. One of them split open before the solder flowed so I put a sleeve of marine type adhesive lined heat shrink over the top of all of them, which is something I do on crimp connectors too.
I'll use these up, but I don't know if I will stop using the crimp type, these are certainly no faster or easier to use, and the one that split gave me concerns about quality.
I bought one of those ring deflectors for the end of the gun, which may allow me to heat the entire sleeve more evenly when using them.
I agree about the properly crimped connectors being important. I had a loose wire on a trigger yesterday with a poorly crimped connector. Someone had squeezed it as best they could with a pair of pliers, but the wire was sliding around in the connector. I hit it with my Klines, slid a piece of heat shrink down over it and sealed it up, all good now.
