rolmops
- Joined
- Feb 24, 2002
- 5,723
It's time to spruce up the Starcraft Islander a bit and after having found some rot in the floor boards I decided to pull the floor, replace the plywood and glue on Marideck vinyl.
In an effort to lighten up the boat a bit I want to go from glassed in 3/4 inch plywood -which rotted out in between the plies- to 1/2 inch plywood covered with the afore mentioned vinyl deck cover. The plywood will lay on foam and in the middle I will add 2 aluminum cross supports above the fuel tank. Yes, I will go on a diet as well.
This boat is trailered and covered when out of the water.
Now I have to choose what sort of plywood to use. I'm in need of suggestions on whether to use marine fir plywood, a high grade exterior plywood or "ultraplyxl" which is way cheaper than the marine stuff and used the same glue as marine fir plywood.
Also, do I to snug the floor all the way up to the transom or do I leave some drainage space which will make the water drip down onto my wooden transom?
Any suggestions and sharing of experience will be highly appreciated.
Thank you, cornelis.
